Mahesh Chamarti
Rep Power: 9 ![]() |
i get this error in cfx pre when i start the solver but not when i save the definition file.
Value of 'Number of Passages in 360' in object '/TURBO POST DATA/TURBO POST COMPONENT:R1', '0', violates its lower bound, '1'. but the no of passages in the rotor is 12 and i passage is being modeled and i am using time transformation for the unsteady simulation.The solver exits with the following message +--------------------------------------------------------------------+ | ****** Warning ****** | | | | Topology simplification is activated with the following | | restrictions: | | | | - Mesh regions referenced only within User Fortran and NOT | | in the command file will cause the solver to stop. | | - The solver will stop during any "Edit Run in Progress" step | | if new 2D regions are referenced. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | c_fpx_handler: Floating point exception: Divide by Zero | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine FPX: c_fpx_handler | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX partitioner exited with return code 1. | +--------------------------------------------------------------------+ please suggest what i can try. |
Maxim
Rep Power: 13 ![]() |
have you double checked if
"Value of 'Number of Passages in 360' in object '/TURBO POST DATA/TURBO POST COMPONENT:R1', '0', violates its lower bound, '1'." If Pre reads it like '0' and not '12' then there's something wrong with the setup. Can you post your ccl? |
dfranken
Rep Power: 10 ![]() |
I have had the same issue as well with no solution so far.
- None -
Rep Power: 6 ![]() |
Hello Everyone,
I am trying to simulate centrifugal pump in CFX. I have this error set the topology estimation factor to be 1.2. I have already changed that to 1.2 , but still the error continues. I have checked my mesh quality which was good in terms of Aspect ratio, orthogonal quality, Skewness etc. My solver runs when I set the value to 2. Does this effect convergence or my results. Any leads would be appreciated! |
Rep Power: 144 ![]() ![]() ![]() ![]() |
If it runs with 2 then just use that.
But this issue is a warning that CFX is having a hard time with something in your simulation. It could be a difficult interface, complex boundary patch or something like that - it is likely to be something in your mesh which is more complex than normal.
#6 | |
jiangsu
Rep Power: 5 ![]() |
Lamp
HARSHITA
Rep Power: 0 ![]() |
Hi ,
I am doing one condensation analysis over a cylindrical surface but when I have tried to run facing this error stated below continuously after lot of trials . Kindly suggest +--------------------------------------------------------------------+ | Topology Simplification | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ****** Warning ****** | | | | Topology simplification is activated with the following | | restrictions: | | | | - Mesh regions referenced only within User Fortran and NOT | | in the command file will cause the solver to stop. | | - The solver will stop during any "Edit Run in Progress" step | | if new 2D regions are referenced. | +------------------------------------------ |
#9 |
Gert-Jan
Rep Power: 27 ![]() |
Does your calculation stop, or not? Because you only show a warning, not an error.
#10 |
Bill
Hi everyone. I had the same issue. It was due to meshing. I used turbomesh for meshing. I changed the mesh structure by adding a layer automatically and then i could run the analysis.
So I guess it is a matter of mesh quality. |
cfx, floating, passages, transient, unsteady |
Command editor is not visible in CFX Pre 17.2 Windows 10 | hmdl | CFX | 3 | December 23, 2020 14:17 |
Green Cones appearing in CFX Pre | lionelopittmanjr | CFX | 1 | February 25, 2017 05:46 |
CEL expression in CFX pre | Jane92 | Main CFD Forum | 1 | June 3, 2016 02:48 |
Only two turbulence options available in CFX Pre | Jack001 | CFX | 5 | March 30, 2016 02:47 |
air ideal gas in CFX Pre | wangy1767 | CFX | 9 | October 1, 2012 07:55 |
