Flow in an Axial Rotor /Stator -Ansys CFX Tutorials |
July 3, 2017, 00:16 |
amiza
Rep Power: 9 |
Hi all,
I am new in using CFX.I am currently working on Ansys CFX Tutorial No.14 - Flow in an Axial Rotor /Stator. During working on this tutorial for obtaining a solution to the frozen Rotor Model, an error occurred in cfx5solve. A dialog box appear stating that ''The ANSYS CFX solver exited with return code 1. No results file has been created. I did run using serial and parallel. But the same note appear during running the simulation. Could anyone here give an advise to solve my problem Thanks Amiza |
July 4, 2017, 02:15 |
Maxim
Rep Power: 13 |
post your complete out-file please. The error message you posted is only part of the complete error.
Alternatively, just delete your progress and start over again. I'm sure there's just a tiny mistake. It'll be quicker if you just re-do it instead of letting us find your mistake... |
July 4, 2017, 04:03 |
amiza
Rep Power: 9 |
Hi Maxim,
I did solved this warning and managed to obtain a solution and successful to view the Simulation Result in CFD Post in Steady and transient state. Thank a lot for your kind reply Best Regards Amiza |
July 4, 2017, 04:11 |
Maxim
Rep Power: 13 |
very good. You could post here what your fix was so that other people that run into the same problem might learn from your mistake
July 4, 2017, 04:22 |
amiza
Rep Power: 9 |
Yes sure.
Kindly, please refer to the attached solution for this problem. Thanks again sir. Best Regards Amiza |
cfx tutorial |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Thrust in Axial flow fan for different inlets | acoustica | CFX | 8 | April 24, 2014 03:44 |
I want to confirm the performance of the axial flow fan. | Sanghyun - PARK | FloEFD, FloWorks & FloTHERM | 1 | October 29, 2013 03:22 |
Fanno flow (pipe flow) in CFX | Saima | CFX | 1 | December 17, 2012 05:36 |
