y+ calculations
Old   May 24, 2002, 09:14
Default y+ calculations
henry
hi
Does any one now how to calculate the distance a near wall cell should be ,if I know the flow details, and I want to maintain the y+ between 30 and 100 as per CFX.
please help.
henry
Old   May 24, 2002, 09:41
Default Re: y+ calculations
cfd guy
In TASCflow and CFX-5 the yplus values at walls are stored by default in the results file. In CFX-4 you only need to add three lines in your command file to see these values under the post-processor.
Regards, cfd guy
Old   May 24, 2002, 11:36
Robin
Actually, TASCflow will only output yplus values if the BCINFO = t flag is set.
As an initial guess before you run for the first time, there are correlations for boundary layer development over a flat plate. Look up section 4.4.4 of the TASCflow doc for details, or Mathmatical Models and Solution Algorithms > Modelling Flow Near the Wall > Guidelines for Grid Generation section of the CFX-5.5 doc (see math_models.pdf).
Regards, Robin
Old   May 27, 2002, 09:45
Michael Bo
http://geolab.larc.nasa.gov/APPS/YPlus/
Old   May 27, 2002, 09:47
henry
hi Thanks for the info,
but I wanted the formula to calculate the Y+
from the flow variables like Re ,etc
henry
Old   May 27, 2002, 10:01
henry
hi
Could some one give the formula please.
joe
Old   May 28, 2002, 09:41
Patrice Jaumouillie
y+, the dimensionless distance from the wall, can be calculated from the formula :
y+=(rho.u*.y)/mu
where rho and mu are respectively the density and the dinamic viscosity of the fluid, y is the distance from the wall and u* is the shear velocity.
The three regions are (may vary from different authors) :
The viscous sublayer 0<y+<5 The intermediate zone : 5<y+<30 The turbulent zone : 30<y+<500
Regards.
Old   May 30, 2002, 17:43
Robin
Have a look at the documentation, it's in there.
Robin
Old   June 3, 2002, 04:38
henry
hi
Patrice thanks soo much ,
do you know how the shear velocity is calculated.
thanks again
joseph
Old   June 27, 2002, 21:48
Min-Hua Wang
Hello, All:
I am very interested in this topic. I am using CFD-4 now. I am trying to export y+ data from the simulation.
It seems to me that one can obtain some meanfull y+ values as the wall is still (not moving). Do I still expect the correct y+ values from the simulation with a standard wall function if the wall is in moving ( bassically the wall is rotating in my study)?
Min-Hua Wang
Hardware for Cfx/openfoam calculations of 30-50 million cells Rkeck Hardware 8 July 13, 2009 13:12
transient calculations! lelia Siemens 9 April 14, 2008 09:33
Mass Flux values and calculations Cb Siemens 1 January 22, 2005 10:21
Difference between two calculations Lennart FLUENT 7 November 24, 2002 02:19
Implicit transient calculations using Fluent5 G. Berntsen Main CFD Forum 4 November 10, 1999 16:32
