Why the Trans_Loop trick does not work? No old time value obtained!
Old   June 28, 2017, 02:10
Default Why the Trans_Loop trick does not work? No old time value obtained!
Ftab
ftab is on a distinguished road
I am trying to calculate an expression in outlet as a function of pressure in last time step.
Searching into the forum I learned to define a new AV and modify it as follows:
LIBRARY:
&replace ADDITIONAL VARIABLE: OldPressure
Option = Definition
Tensor Type = SCALAR
Units = [Pa]
Update Loop = TRANS_LOOP
Variable Type = Specific
END
END
As you can see I have modified the update loop to get the pressure data at old time step.
Then I define the AV as follows:
FLUID MODELS:
Additional Variable Value = Pressure
Option = Algebraic Equation
END
I also do the 1 iteration initialization with Zero.
The problem is: I monitor Pressure and OldPressure and they are the same. It seems I do not get the Pressure in old time step. WHY?
Any comment? It seems several people has managed to do it here.
Thanks
ftab is offline   Reply With Quote
Old   June 28, 2017, 02:51
urosgrivc
urosgrivc is on a distinguished road
Hi
I have also had similar problems, with (avgvol Temperature gradient(x,y,z)).
We would appreciate if someone could explain in a simple way how translooping can be done
Because I would really like to use it more.
It is a pity that this does not already have a dedicated button in cfxpre.
I have read everything about it here on the forum but other than here not much can be found about it.
Can it only work for single value or can it be a domain variable. Single valued worked for me once, but I must be doing something wrong now.
So I am also wery interested in this topic.
Thank you
urosgrivc is offline   Reply With Quote
Old   December 31, 2018, 03:19
Zhiyuan Liu
Saeef is on a distinguished road
Originally Posted by ftab View Post
LIBRARY:
Option = Definition
Units = [Pa]
END
END
FLUID MODELS:
END
Thanks
Have you settled this problem?
I'm also troubled.
Saeef is offline   Reply With Quote
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
