Inlet static pressure
Old   May 13, 2002, 12:24
Default Inlet static pressure
VEEBS
Dear TASCFLOW Users,
How to specify the inlet with static pressure ? It looks the moment we say pressure type, it takes default to total pressure option.
Thanks Veebs
Old   May 13, 2002, 14:03
Default Re: Inlet static pressure
Robin
Hi Veebs,
If you define your inlet as an "Opening", rather than "Inlet", you can specify the static pressure by using the constant or face option (the mixed option will apply it as a total pressure if flow is entering).
Generally, specifying static pressure at an inlet is undesirable. At any location, the static pressure should be in equalibrium with the neighboring values. By specifying total pressure, velocity or mass flow, the code can acheive this equilibrium. This will also be the case with the static pressure specified at a face for an opening, although flow will be free to move in both directions. The face option sets the static pressure at one face and allows the rest to float with that as a constraint.
Are you sure a static pressure is what you want? What is the physical nature of your boundary condition?
Robin
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 01:11
How to achieve constant static pressure in inlet? Zou Jianfeng FLUENT 0 October 21, 2008 02:55
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 15:57
Pressure Inlet yields wrong velocities Ben FLUENT 0 November 21, 2004 02:47
