May 13, 2002, 06:33 |
5.4.1 Solver Error
Hi all,
I would like to ask the meaning of this solver error and the method to fix it. The error message is followings, -------------------------------------------------- Error in subroutine GET_USTAR: Error calculating USTAR GETVAR originally called by subroutine cTWFTFC2 -------------------------------------------------- ERROR #001100279 has occurred in subroutine ErrAction. Message: Stopped in routine GV_ERROR -------------------------------------------------- Anyone can help me? Thanks in advance. Best regards, Sara |
May 13, 2002, 18:37 |
Re: 5.4.1 Solver Error
Do you have the 5.4.1 patch installed?
Neale |
May 13, 2002, 23:57 |
Hi Neale,
Is it that I can check it from the CFX5-Launcher/ Show/ patches? It shows, "Output from cfx5info -patches: CFX-5.4.1 (c) 1996-2000 AEA Technology. All rights reserved. No known patches are installed." Does it mean no patches are installed?? Sara |
May 15, 2002, 18:41 |
Yes, that is correct. I suggest you get the patch installed and then try again.
Neale. |
May 15, 2002, 23:35 |
Thanks!
Hi Neale,
Thank you very much!! ^_^ Sara |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
