June 26, 2017, 10:25 |
Expression value in output window
Rep Power: 10 |
I was wondering if it is possible to output the value of expressions for every iteration? I can create an output monitor but it only plots the values in monitor plots, not the output console, unless I am missing something?
June 26, 2017, 11:07 |
Maxim
Rep Power: 13 |
via the command line command "cfx5mondata" you can extract the data of your monitor points and save to a *.csv file.
Ansys help or this forum will give you enough information and examples to use this command. |
Problem About Running Fluent In Linux | mitra | FLUENT | 18 | June 20, 2019 03:11 |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 06:52 |
RNG diverged during the analysis the flow over a multi element airfoil, why? | s.m | OpenFOAM Running, Solving & CFD | 0 | August 5, 2013 09:39 |
Help with DPM UDF for OUTPUT needed | Zhengcai Ye | FLUENT | 0 | January 5, 2004 17:58 |
Creating, loop or iteration using expression edito | Jan | CFX | 3 | July 28, 2003 12:01 |
