Molecular weight of the solid phase?
Old   May 8, 2002, 14:16
Default Molecular weight of the solid phase?
imburse
I am trying to simulate a 2-phase flow. One phase is gas, the other is solid particulates. But the *.fc file failed to be run by the CFX solver. The generated *.fo file keeps telling me fhe following,
####> ERROR. IN DATA FOR PHASE 2 THE MOLECULAR WEIGHT = -1.0000E+00 THIS MUST BE SET BY THE USER AND HAVE A value GREATER THAN 0.0
THE CFX-4 SOLVER HAS BEEN STOPPED BY SUBROUTINE SPEC1
Can anyone please tell me in what part of the *.fc file I am supposed to set the molecular weight for the solid phase? Thanks in advance.
Old   May 8, 2002, 18:20
Default Re: Molecular weight of the solid phase?
Jan Rusaas
The reason for the error could be an error in your command file. Try to open the command file from within the enviroment, if you have made some simple spelling errors or mismatched in the command language they will be removed.
Old   May 9, 2002, 19:18
imburse
I did build the command file from within the CFX environment. There is no grammar mistake with it. My question is, besides the PCP database, is there any other way by which I can set the physical parameters (molecular weight, thermal diffusivity) for the solid phase of a multi-phase flow (one phase is gas, the other is solid particulate).
Old   May 9, 2002, 19:28
CFXboy
From what I understand, you are running a compressible flow simulation by setting the gas to compressible and solids phase to incompressible. It shouldn't ask you for the molecular weight if the solid is set as incompressible, unless there are reaction in there. You can set the molecular weight of the fluid as follows:
>>PHYSICAL PROPERTIES
>>COMPRESSIBILITY PARAMETERS
PHASE NAME 'GAS'
FULLY COMPRESSIBLE
UNIVERSAL GAS CONSTANT 8.3140E+03
FLUID MOLECULAR WEIGHT 2.8970E+01
REFERENCE PRESSURE 1.0130E+05
PHASE NAME 'SOLID'
INCOMPRESSIBLE
Hope this helps.
Pressure and molecular weight ? Jane FLUENT 0 January 2, 2009 05:17
Viscosity for solid dispersed phase in E-E modelin Kushagra FLUENT 0 June 27, 2008 20:01
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
How to calculate density of solid phase zhou Main CFD Forum 0 December 17, 1999 20:06
