CFX-Post under 5 micron
Old   May 8, 2002, 09:37
Default CFX-Post under 5 micron
lego
Hi all!
We've experienced an intresting and prety error. The CFX Post can not display elements has edges under about 5 microns. I solved a problem in which there was a mesh control of less than 5 micron. In this region I can not display the results.
What can I do to solve this problem?
Old   May 8, 2002, 12:15
Default Re: CFX-Post under 5 micron
Bouke
Just as an idea for a workaround, you might try to create a coarser grid just for display purposes and interpolate the fine-grid results onto that (this is of course not satisfactory if you are interested in flow details in the 5 micron scale).
Old   May 9, 2002, 09:15
Default It is a problem of my boundary layer
lego
I calculate a very high Reynolds-number flow of about 0,02 mm thick turbulent boundary layer. So I use inflation, in which the thinest layer is less than 10 micron thick. And I can not display it. I think some kind of tolerance value should be reset. How can I do it?
Ciao: LEGO
How to get reynolds stress values in POST CFX syler3321 CFX 6 January 1, 2017 08:54
CFX post legend modification mactech001 CFX 3 December 25, 2011 23:12
CFX post - graph kmgraju CFX 0 July 22, 2010 12:59
Chart Generation in CFX Post Vadim Baines-Jones CFX 2 August 28, 2007 10:14
Tecplot for CFX post processing pantangi goud CFX 2 August 24, 2005 17:42
