How to define momentum source?
Old   May 5, 2002, 13:45
Default How to define momentum source?
Bogesz
In CFX build 5.5 I want to define linear resistance coefficient. In which direction (u, v, or w) of the velocity will it take effect? Because the Help says the linear (or quadratic) resistence coefficients are related to the x, y or z components but in the source definition window of Build I can define by components only the momentum source, for the coefficients there's no option to define which velocity component I want to handle
THX Bogdan
Old   May 6, 2002, 15:44
Default Re: How to define momentum source?
Neale
It's isotropic resistance in all three directions. You can't currently specifically do x, y or z independently.
Neale
Old   May 10, 2002, 06:31
alain
If you want to define an anisotropic resistance coefficient, you can use the momentum source term with an adequate CEL expression for linear or quadratic source term.
Alain
Old   July 23, 2002, 04:25
kim nag jeom
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 07:10
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 05:26
momentum source in half-cylindrical null objects Noel Phoenics 1 December 16, 2008 06:51
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 11:19
Define source Ridha FLUENT 0 November 2, 2002 19:15
