Hi everybody,
I want to run CFX-5 from the console, preventing the graphical residual monitor which consumes some memory, and I don't get the output of the running solution (residuals in text mode, only values) in my console window which I originally called the CFX-5 solver. I suspect that there may exist an extra parameter not shown in the manual. Well, this is how I call the solver: cfx5solve.exe -def [file] -ini [restart_file] I've tried the -v (verbose) option but I didn't get any output in the console window. So, any hints? Sincerely, cfd guy |
Firstly, for all the solver options type "cfx5solve --h"
The solver is put into the background automatically, so you cannot get a live update. The output is written to the out file during the run (look in the temporary subdirectory runName_001.dir/out ). If you wish to view the outfile as it updates, use the unix tail -f command. The -f flag tells it to follow the file as it updates. If you are on NT, download and install cygwin to get tail and other unix commands. Robin |
Thanks Robin,
I work on NT and I've tested the tail command under cygnus and worked very well. I forgot to tell. This doubt also apply to CFX-TASCflow. Suggestion: Perhaps in the next updates of CFX-5 and/or CFX-TASCflow we can get an option like this: cfx5solve -tail or tascflow3d -tail , etc... Regards, cfd guy |
Compressible Flow in Ansys CFX | bcheruk | CFX | 15 | July 6, 2017 07:30 |
Importing solutions in CFX. | Alphonso | CFX | 1 | August 1, 2008 15:01 |
Does CFX can output ".rth" file? | prayskyer | CFX | 6 | July 7, 2006 21:08 |
is "double precesion output for cfx" default? | charles | CFX | 3 | May 17, 2006 15:40 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
