Bulk temperature expression gives value below inlet temperature for half the pipe
Old   June 18, 2017, 18:21
Default Bulk temperature expression gives value below inlet temperature for half the pipe
Shomaz ul Haq
Shomaz ul Haq is on a distinguished road
Send a message via Skype™ to Shomaz ul Haq
Dear all,
Hello. Hope all are well. I have a question. One that is answered by many posts but I really couldn't find my answer there unfortunately after two weeks. My bulk temperature expression for pipe is
(Inlet Temperature)+((Wall Heat Flux*Pi*Diameter*Z)/(Density*Pi*Radius^2*Velocity*Specific Heat Capacity at Constant Pressure))
where my
Diameter=0.02 m
Inlet Temperature=293 K
Specific Heat Capacity=4048.42 J/kg/K
Velocity=0.022 m/s
Wall Heat Flux=1000 W/m^2
My bulk temperature gives a value less than 20 C by a certain fixed amount for half the length of the pipe and greater than that for the rest half of the pipe. I have started my flow from 0.5 m to -0.5 m.
Is my expression correct? I found it in a reference posted by a senior in this forum. I think so but please check.
My heat transfer coefficient values are coming about to be in the range of 100-150. That is very low as compared to literature for laminar pipe flow at similar Re numbers and ~10-20 mm diameters. When I check default heat transfer coefficient variable values they are from 6000-7000 which I know is correct and due to calculation based on Adjacent Wall Temperature chosen by cfx and is mesh dependent giving a large value as my mesh is relatively refined. But I don't want to use those values as I can't compare them to literature because of their non-applicability. The even stranger thing is that Nu number calculated using the same htc is around 4.364 at the end of the pipe validating my model. So does that mean that my calculation for bulk temperature is wrong? Confused!
Would be grateful if someone could help me out. Hope to hear from someone soon. Thanks.
Shomaz ul Haq is offline   Reply With Quote
Old   June 19, 2017, 17:47
Erik
evcelica is on a distinguished road
Make sure your expressions are not pre-defined variables like Velocity, Density, Wall Heat Flux. Your z value should be (z-InletZ).
evcelica is offline   Reply With Quote
Old   June 19, 2017, 19:58
Shomaz ul Haq
Although none of my expressions are any variables, my expressions does contain some variables like Wall Heat Flux in expression for h and so on. I think that is inevitable. Did you mean I shouldn't use any variables in my expressions? Didn't understand your advice. Thanks.
Old   June 21, 2017, 04:40
Shomaz ul Haq
Dear all,
Hello. Waiting for your help. Thanks.
What is the accurate and best way to calculate bulk or mean temperature? Shomaz ul Haq FLUENT 9 December 23, 2018 04:48
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Bulk Temperature Problem 4asino Main CFD Forum 0 June 12, 2015 09:39
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 07:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
