Error in CFX5.4.1
Old   April 20, 2002, 10:00
Default Error in CFX5.4.1
Sara
Hi all,
I've got a error in the Solver of CFX 5.4.1 as following,
"Fatal error generate in gJacmFcIp
Message: -Full: Fail to make a data area for JacmFcIp gJacmFcIp called by:- gNarvFcIp
ERROR#001100279 has occurred in subroutine ErrAction.
Message: Stopped in routine gJacmFcIp"
Anybody can kindly tell me the meaning of this error message? and suggest me how to fix this problem? Thank you very much.
regards, Sara
Old   April 21, 2002, 02:01
Default Re: Error in CFX5.4.1
Neale
The solver has run out of real stack space. Increase the amount of real memory (in words) it allocates in the solver manager. Or, you can simply specify a multiplier, say 1.2 or something like that.
In 5.5 this is much more flexible by the way. i.e., you have much more control over the memory allocation, and the error messaging about running out of memory is much friendlier.
Neale.
Old   April 22, 2002, 14:49
Sara
Hi Neale,
Thank you very much for your suggestion and idea. They help me a lot. Thanks!! =)
regards, Sara
Import iges file into CFX5.4.1 in Unix system yli CFX 2 May 5, 2003 09:49
CFX5.4.1 yli CFX 1 May 1, 2003 09:46
CFX5.4.1 --> CFX5.5 Sara CFX 4 July 10, 2002 05:50
turbulence modelling in cfx5.4.1 krishna CFX 0 May 13, 2002 13:47
CFX5.4.1 Sebastian CFX 1 April 12, 2001 07:41
