Error Message during transient run on a cluster
Old   June 17, 2017, 04:18
Default Error Message during transient run on a cluster
balrog_f is on a distinguished road
Hi guys,
I am getting the following error message during a transient run when I am running on a cluster. I dont know why this occurs because the continue history from option is enabled. Where could this problem come from? Anybody has an idea? I am averaging over 20000 timesteps but I can only run 10000 timesteps in one session on the cluster so i have to make to runs for averaging. The problem only seems to occur for the wall shear, not for pressure and velocity, which I am also averaging over the same time.
Parallel run: Received message from slave
Slave partition : 18
Slave routine : ErrAction
Master location : after reading the def-File
Message label : 001100279
Message follows below - :
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| When computing the Transient Statistic "TRNAVG(TAUWVEC_FL1)" the |
| current iteration (****) is greater than the statistic Start Iter- |
| ation (****), but existing data cannot be found. Users should rev- |
| iew the specified start-stop values and, if this is a restart, th- |
| e run history continuation settings. |
The message occurs for a few partitions.
balrog_f is offline   Reply With Quote
How to extract data from a completed transient run Vince CFX 3 November 26, 2019 06:59
Run OpenFoam in 2 nodes of a cluster WhiteW OpenFOAM Running, Solving & CFD 16 December 20, 2016 01:51
Pinning the processors in cluster to run a solver coolcrasher OpenFOAM Running, Solving & CFD 0 November 5, 2015 07:11
run parallel distributed in cluster fevi84 FLUENT 0 June 18, 2012 18:41
Cycling a transient run Chetan Mistry Phoenics 0 March 3, 2004 10:50
