CFX rotating Domain
Old   June 16, 2017, 07:49
Jules
cfxbeginner is on a distinguished road
I have a computer problem so I will do it this afternoon.
I have read a Training manual and find that if we create a rotating domain the CFX-Solver computes the appropriate Coriolis and centrifugal momentum terms.
Could it be my problem?
Here is the text
cfxbeginner is offline   Reply With Quote
Old   June 16, 2017, 08:01
No, it should not be.
Go back to the definition of a frame of reference is. It is simply something to measure distances and velocities relative to. While the velocity is different values in different frames of reference, the velocity in the absolute frame of reference is unchanged. To change the velocity you need something physical - a wall, pressure gradient or something like that.
So the test you have done is a good check that simply adding a rotating frame of reference does not change the flow in the absolute frame. The fact that it appears that it is changed means something is wrong.
Old   June 19, 2017, 08:05
Jules
I simplified a bit my problem and stop the inlet velocity. The velocity near the interface seems not to be null and the velocity in the rotating domain is smaller but the fluid seems to rotate.
Are These perturbations due to GGI parameters or my mesh? What can I do to improve it?
Old   June 19, 2017, 08:45
urosgrivc
urosgrivc is on a distinguished road
Do you think that this is the cause?
Velocity here has a magnitude something to e10-4
Results vhich are problematic described in previous page are in orders of few 100% wrong ,that is wierd i think that this is negligable compared to those figures.
urosgrivc is offline   Reply With Quote
Old   June 19, 2017, 11:24
Jules
I don't see any other explanations. Is it possible that the fluid velocity increase these little errors? I really don't understand what is my mistake ...
The solution with an hexa-mesh seems to be worst... I'm now trying to improve my mesh.
Old   June 21, 2017, 12:00
Default Imbalances
  #26
LorenzoSaintDubois is on a distinguished road
did you take a look at the imbalance values? The CCL that was posted did not include them under the convergence criteria... It can be that the residual convergence is tight but the imbalances are completely off, so the physical solution doesn't make sense.
Good luck,
LSD
LorenzoSaintDubois is offline   Reply With Quote
Rotating or stationary domain in pump/turbine cavity Christian Høy CFX 3 March 17, 2017 07:03
convergenceof natural convection prob. in cfx cpkewat CFX 15 January 31, 2014 07:29
injection problem Mark New FLUENT 0 August 4, 2013 02:30
Different conductivities for a SINGLE domain for CHT problem in CFX Mehul CFX 3 August 3, 2012 10:01
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 07:14
