Internal Static Pressure in a tank - ANSYS CFX
Old   June 13, 2017, 09:51
Default Internal Static Pressure in a tank - ANSYS CFX
glik
glik is on a distinguished road
Hello everyone,
I would like to make a tank for my internship.
My subject is "Numerical Simulation of a tank submitted to an earthquake".
I have some problems :
1) Inside my tank, I have water and air. But I have a problem with the interface when I had a horizontal acceleration to simulate the seism. Do I have to use "Free surface model" ? Or maybe it's the sizing mesh, but I have already do something about it.
I put a picture as attachment. In red the water, in blue air.
2) I can't add an internal pressure. In inizialization settings, I add it, but I can't see any changement in the post-proc.
Does someone have any idea ?
Thanks a lot
File Type: png modele 5 a acc horizontale gimp - Density.png (56.9 KB, 8 views)
glik is offline   Reply With Quote
Old   August 9, 2017, 17:09
Default interface--> Definition
Fernando
camposrf is on a distinguished road
Originally Posted by glik View Post
(...) I have a problem with the interface when I had a horizontal acceleration to simulate the seism. (...)
I had the same issue with the interface. I defined the volume fraction and obtain this:
you can read more at my post
CFX 10.0 If command
camposrf is offline   Reply With Quote
Old   August 16, 2017, 11:07
glik
Which condition did you use for the top ?
And with a thinner mesh it should be better
Old   August 17, 2017, 08:16
Default approximation cases first before run
Fernando
Originally Posted by camposrf View Post
(...)it is a coarsed one. I have to do approximation cases first before run a detailed model “if I want the results this year” (joke). Further more, it has a worst residuals convergence (0.01). The good news is that the time step is ok because it is a steady simulation.
I have to do this previous work because I do not have a powerful PC. I accept donations (is not a joke).
For the top I used opening as boundary condition at 0 KPa.
Yes, with a thinner mesh it will be better; I will use the refined one when I get some reliable results.
My priority is get rid of the common errors first. At the beginning I do a steady simulation, then the transient, and finish with the refined mesh.
Old   August 17, 2017, 08:25
Default Sloshing tutorial
Fernando
I found these tutorial, maybe it could help you.
https://www.youtube.com/watch?v=oIFfPEWHkxw
https://www.youtube.com/watch?v=SwSbXwIKoto
Urgent: How to model a stationary sphere in a pressure driven flow using Ansys CFX? farhan OpenFOAM Running, Solving & CFD 1 April 14, 2009 14:34
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 01:10
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Static vs Total Pressure Alfonso Ferrandez FLUENT 2 May 23, 2000 08:53
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
