How much does a skewed element effect a solution ?
Old   April 5, 2002, 10:44
Default How much does a skewed element effect a solution ?
joseph
HI
How much does a skewed hexahedral element effect a solution in CFX 5.5 ?(structured grid),especially in a MFR problem
what is the least angle recomended by CFX 5.5. from 0-90 deg?
thanks
joseph
Old   April 6, 2002, 00:43
Default Re: How much does a skewed element effect a soluti
Neale
CFX-5 can handle fairly bad skew angles, say >10-20 deg. The quality of the solution is going to rely mainly on how many you have. If 50% of your elements are skewed, then your going to have a tough time, and you will probably get a bad answer. If 5% are skewed, then you might be OK.
Neale
Old   April 7, 2002, 18:10
steve
It depends a lot on where the cells are, i.e. in the far-field where the flow is roughly constant the solver will have little problem with highly skewed cells. However in the boundary layer or in the vicinity of a shock you should have orthogonal cells.
The best way to check if skewed cells are degrading the solution is to perform a grid convergence test - i.e. double the grid resolution and see if the results change. You should also plot the residuals in post and see if the largest residuals are in the highly skewed cells.
Old   April 8, 2002, 01:21
Default thank you steve and Neale
joseph
hi,
thanks for your valuable comments.
Joseph
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 22:22
Does FOAM converge to exact solution in Laplace equation? santiagomarquezd OpenFOAM Running, Solving & CFD 0 March 26, 2010 08:52
Effect of Grids on Solution Andrea Main CFD Forum 6 May 13, 2007 22:34
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
