April 4, 2002, 05:54 |
Parallel computation problem in Tascflow
Dear all CFX users,
Does anyone have experience on parallel computation by using of cfx-tascflow. What I was doing is a problem about simulation of transient Rotor/Stator. Every time I tried to run it on a parallel model the system is stoped due to memory insufficent. Actually, my computer possess enough memory to do this work when I run it on a serial model. Does anyboy can help me on it?I will look forward to your responses. Best regards, Dandy |
April 4, 2002, 20:53 |
Re: Parallel computation problem in Tascflow
Not enough REAL workspace in "GENGRP".
In order to recover, set the following parameters in the PRM file: GGI_RESTART = F SLIDING_RS_START_THETA = 0.2011082E+02 SLIDING_RS_MEMORY_FACTOR > 1.0 Make sure that these parameters are deleted from the PRM file for subsequent simulations (post-recovery) |
April 18, 2002, 11:56 |
Just increase the memory settings you are using. Memory required for parallel is a little different than serial.
April 21, 2002, 01:32 |
But it still doesn't work......
problem using property udfs in parallel mode | EllenW | Fluent UDF and Scheme Programming | 5 | July 10, 2009 05:31 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 16:41 |
problem using property udfs in parallel mode | EllenW | FLUENT | 0 | June 23, 2009 18:18 |
transient, parallel - problem with timestep | Peter | CFX | 5 | March 8, 2005 17:15 |
CFX-5.7 MPICH Parallel Problem (Output of Results) | James Date | CFX | 7 | February 15, 2005 17:03 |
