ERROR #001100279 has occurred in subroutine ErrAction. |
June 5, 2017, 18:46 |
srcredchi
Rep Power: 9 |
I was trying to run two way FSI using CFX, I got following error
ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | CFX encountered the error: Read. Fatal error occurred when reque- | | sting Total Mesh Displacement for Interface. | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | cplg_SendCommand failed to send the command: ERROR -- CFX encount- | | ered the error: Read. Fatal error occurred when requesting Total | | Mesh Displacement for Interface. | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine cplg_SendCommand | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. Can anyone tell me what is this error and how to solve it? |
June 5, 2017, 20:51 |
Rep Power: 144 |
The important error is the first one. CFX did not get the mesh displacement from the FEA side of things. Check that the FEA simulation was running, and that the interface between the two is correctly set up.
June 5, 2017, 21:49 |
#3 | |
srcredchi
Rep Power: 9 |
I am trying two way FSI of very highly flexible oscillating strip. When I was using harder strips it is working fine, but when I used soft flexible strips I am getting this error. |
May 22, 2019, 19:58 |
2 way FSI
Rep Power: 7 |
I have the same problem when I try to solve a highly flexible pipe oscillating in a fluid. The model works for a stainless steel pipe but not for a silicon pipe. I was wondering if there is any solution.
error #001100279, subroutine erraction. |
Compiling User Fortran with CFX 14.0 on Win64 | Raijin Thunderkeg | CFX | 29 | March 9, 2016 12:45 |
"ERROR #001100279 has occurred in subroutine ErrAction ... no frame change model" | darker2230 | CFX | 3 | November 10, 2015 07:56 |
ERROR #001100279 has occurred in subroutine ErrAction. | aniseh | CFX | 6 | October 5, 2015 12:01 |
ERROR #001100279 has occurred in subroutine ErrAction. | sujay | CFX | 8 | December 10, 2014 13:09 |
ERROR #001100279 has occurred in subroutine ErrAction. | P9408 | CFX | 1 | August 19, 2009 08:56 |
