Edge matching
Old   March 14, 2002, 02:38
Default Edge matching
Jens
I have a problem when creating a solid from surfaces.
I keep getting the error:
"A Gap exists between two of the faces in the Body. This may be due to edges not matching directly or a missing face. Edges are highlighted. Use Edit/Surface/Edge Match to close the gaps, then use Create/Solid/Brep to create the solid."
And then all edge are highlighted.
I have tryed Edit/Surface/Edge Match and Edit/Surface/Sew, but this does not help !
Any help is welcome.
Regards
Jens
Old   March 14, 2002, 09:06
Default Re: Edge matching
cfd guy
Hi Jens,
Which CFX-BUILD are you using? BUILD 4 or BUILD 5 ?
Regards, cfd guy
Old   March 14, 2002, 09:50
Jens
Hi
I am using CFD-Build 5.
Thanks in advance.
Kind Regards
Jens
Old   March 14, 2002, 13:37
cfd guy
Hi
In Build 5 you can work with BRep solids (color is white) and Tri-Parametric solid (dark blue). And there are two kind of surfaces you can work in BUILD 5, Bi-parametric (default color is green) and Trimmed (default color is magenta). So if you want to build a solid (BRep) you must select all your external surfaces to obtain a completely closed volume. If you forget one or more faces, BUILD will highlight it as missing edges giving you the message you posted. In the other hand you can work with the dark blue ones, but it's more practice to work with BRep, it's much more easier. I'll give you a simple example: Create a single surface...
Create - Surface - XYZ Origin: [0 0 0], Vector <1 1 0>
Create - Solid - Extrude Origin: [0 0 0], Vector <0 0 5>, Select the surface you created
Now you have a dark blue solid (Tri-Parametric). Break the solid into several surfaces: Edit - Solid - Disassemble Select Solid 1 and YES (Delete original solids)
And finally you can make your BRep solid selecting all the remaining surfaces (6 surfaces). I hope you understood me.
Good luck! cfd guy
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 02:07
