June 1, 2017, 08:00 |
#21 |
AKS
Rep Power: 14 |
Dear Ghorrocks,
Can I expect that my post #12 using sub domain option is modeling the periodic part of the temperature profile correctly ? |
June 1, 2017, 08:06 |
#22 |
AKS
Rep Power: 14 |
For constant heat flux condition, the temperature can be represented as:
T = T(periodic)+gamma*X; gamma is global temperature rise. T(periodic, X)=T(Periodic, x+L); L is length of period |
June 1, 2017, 08:24 |
#23 |
Rep Power: 33 |
Your nomenclature is a bit confusing since it uses 1 or 2 arguments.
For a uniform (and constant) heat flux boundary condition, the fully developed temperature profile is linear in the streamwise direction; therefore, it can be said that for section of the pipe in the developed region and periodic sub-model can be set using a boundary condition such as Tb (X+L) = Tb(X) + Delta_T where Delta_T is determined a energy balance between those two sections. Since we know the length of the section, superficial area of the heat flux boundary, mass flow and specific heat capacity, we can write areaIntegral (density* velocity * Cp * T(X+L)) - areaIntegral (density * velocity * Cp * T(X)) = HeatFlux * Superficial Area by definition of bulk temperature, the above can be written as massFlowCp * (Tb(X+L) - Tb(X)) = HeatFlux * Superficial Area therefore, Tb(X+L) = Tb(X) + HeatFlux * Superficial Area / massFlowCp For constant property materials, it can also be written for the local distribution, say radial T(X+L, r) = T(X,r) + HeatFlux * Superficial Area / massFlowCp Question: how are you imposing the translational periodicity with a temperature jump ? |
June 2, 2017, 03:28 |
#24 |
AKS
Rep Power: 14 |
I am following the similar analysis. So, I am solving for the periodic part of temperature using source term in the subdomain (Post # 12). As you can see, the temperature at inlet and outlet are in good match.
Next, to obtain the actual temperature, I have to just subtract Delta_T, which can be obtained using gamma*X. I get good results; but the only problem is nusselt number value which is coming near about 6.07. Here, basically I am solving for the periodic temperature using source term giving T(X+L, r) = T(X,r) For temperature jump, i need to return back to my actual temperature. Last edited by cfd_begin; June 2, 2017 at 04:37. |
CFX Multiphase - Fluid-fluid heat transfer | nasir | CFX | 3 | June 15, 2014 18:44 |
CFX Multiphase - Fluid-fluid heat transfer | nasir | CFX | 0 | June 14, 2014 06:21 |
CFX wall heat transfer coefficient | mactech001 | CFX | 1 | January 5, 2010 21:33 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 21:25 |
