May 28, 2017, 10:14 |
Y+ Value Plotting in CFD Post
Rep Power: 14 |
Hi
Is there any way that we can plot the y+ value along our geometry ? When I do a plane and take its contour for y+ in CFD post I can see the value from 0 to 25 but the contour remains grey plane. There its not showing where these values are. So I am not sure where is 25 where is around 0 !! So what is the possiblity ? Also I want to see the log law and z+ values. How can we do these ? Kindly let me know. I did K-W model and for that y+ have to be less than 1 and for LES WALE model what is the y+ criteria ? |
May 28, 2017, 18:36 |
tick; new var
Svetlana Tkachenko
Rep Power: 14 |
In the tree view at the left, tick the box next to the contour. If this does not help please attach a screenshot. To create new variables, use the expressions and variables tabs at the top. Create expression first and then create a variable which uses that expression as the formula. There is a tutorial about it here: CFD-Post tutorial - Step 15: Create a Custom Variable and Animate the Display. Last edited by Svetlana; May 28, 2017 at 18:37. Reason: add title |
May 29, 2017, 02:45 |
Rep Power: 14 |
Hi
I did it and still it was grey. But when I select the wall option in the contour I can see the y+ along the wall. |
May 29, 2017, 07:31 |
D. N. Venturi
Rep Power: 13 |
By definition, Y+ is only calculated at the wall. That is why you'll only be able to see it in the walls. The plane is gray because there is no Y+ values for the inner cells.
Problem in CFD -post | pratikvn | ANSYS | 4 | March 21, 2018 02:56 |
Post-processing star ccm+ results in Ansys CFD Post | sidharath | STAR-CCM+ | 4 | April 10, 2017 11:49 |
Post processing in CFD Post or Fluent. | Blobs | OpenFOAM Post-Processing | 2 | June 26, 2016 07:23 |
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 19, 2015 23:40 |
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 00:30 |
