CFX-5.5: Meshing subdomain with inflation
Old   February 14, 2002, 11:00
Default CFX-5.5: Meshing subdomain with inflation
Bogesz
Simple geometry: large cylindrical flow volume with volumetric heat source in the first half, that's why I need a subdomain. This subdomain fills the whole volume in the first part of the fluid-domain and the fluid after exiting the subdomain flows on through the rest of the cylinder. I need inflated boundary on all the inner walls of this geometry but Build doesn't make me a def file. (for example if I wan't to use the "Type: Bound Conditions" with "Select Current Walls" option) Most common error message: surface volume is self intersecting
Looking forward to your help
Thanks
Bogdan
Old   February 14, 2002, 19:43
Default Re: CFX-5.5: Meshing subdomain with inflation
Robin
Bogdan,
Have you tried selecting the surfaces, rather than using the boundary condition option? Give it a try with only a few surfaces first. Sometimes there may be a single surface that is giving you grief, when excluded you can at least get inflation on the rest.
Also, have you downloaded the recent patches from ftp site?
Robin
Old   February 15, 2002, 05:27
Bogesz
Thanks but for both question my answer is yes... My experience is that the problem is with the subdomain stuff. If I leave some space (very litte is enough) between the end of the subdomain and the inflated part of the rest (so it looks like [inflated subdomain]..[the rest with inflation]) it's ok but it is very ugly...
Help regarding basic airfoil meshing in CFX amoolraina ANSYS Meshing & Geometry 2 May 22, 2010 19:51
Which trailing edge is correct for meshing of aerofoils for CFX LSC CFX 0 May 10, 2009 13:45
CFX Meshing Error! C Mc Guinness Main CFD Forum 0 April 3, 2005 14:20
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
cfx, meshing + examples mark Main CFD Forum 1 December 22, 2000 00:10
