CEL expression for normalizing temperature in CFX pre
Old   May 25, 2017, 04:48
Default CEL expression for normalizing temperature in CFX pre
Shahid Parvez
shahpar73 is on a distinguished road
Hi
I am simulating a heat transfer problem in which I get temperatures on a plane surface varying from 300 [k] to 2700 [k].
For some reasons, I want to develop the following CEL expression in CFX-Pre;
Distance = 2[mm]*(T>=1750[K])/maxVal(T)@surface
i.e. I want to divide temperature which is equal to or greater than 1750 [k] by the maximum temperature on the surface and multiply by 2.
I tried but failed to "Evaluate" with the following error
ERROR
At least one operand of arithmetic operator is logical valued.
Error detected for '*' operator at position 2.
Can someone help please... (SOLVED, thanks)
shahpar73 is offline   Reply With Quote
Old   May 25, 2017, 08:22
You cannot arbitrarily change solver variables like that. Numerical solvers do not work that way.
If you want to manually set a temperature to a certain value then use a source term. Have a look in the CFX documentation on how to set source terms to set variables to specific values.
But I recommend this is VERY bad practise. You are getting crazy temperatures because either you have missed an important piece of physics or your simulation is numerically unstable. You should fix the missing physics or the instability to eliminate the problem, not try to patch over it as your suggestion would do.
CFX Pre & Post Startup Error vigges CFX 12 March 17, 2023 04:30
Writing expression in CFX Pre using Cell Volume debabrata.mahapatra CFX 1 July 21, 2014 09:51
What is the CEL expression for the logical command 'else if' in CFX pre Anna Tian CFX 1 June 26, 2013 13:21
CFX Expression Language help JuPa CFX 3 April 21, 2013 08:46
Temperature dependent thermal property in CFX Subhadeep CFX 5 March 22, 2012 02:52
