CFD post case compare
Old   May 22, 2017, 07:38
Default CFD post case compare
Mohammed Ameenuddin
ch@resch is on a distinguished road
Hi all,
I have two different cases say, "flow 1" and "flow 2". I would like to plot the percentage error of wall shear stresses in CFD post.
((WSS1-WSS2)/WSS1)*100
After going through the manual, I have used case comparison, but it only calculates the difference between the two cases. Then i tried making a variable,
percent error = (Wall Shear.Difference/Wall Shear)*100.
I feel the value that i get after I use it is not right. Because I am not sure the "Wall Shear" here refers to which case flow 1 or flow 2.
Then again I tried using another form say,
percent error = (Wall Shear.Difference/Wall Shear.Case:1)*100
I get a syntax error
Successfully read 37 characters:
Wall Shear.Difference/Wall Shear.CASE
then error detected at:
:1
Details - Unexpected character.
I am not clear on how to get the percent error from two cases. Any kind of help regarding this would be appreciated.
Thanks and Regards
ch@resch is offline   Reply With Quote
Old   December 7, 2022, 10:02
CFD_new_user is on a distinguished road
Did you find a solution to this?
CFD_new_user is offline   Reply With Quote
cfd - post, percent error
CFD Salary CFD Main CFD Forum 17 January 3, 2017 18:09
Outputting the Particle Re to CFD Post cvh CFX 0 April 12, 2016 01:13
Problem regarding producing streamlines from surfaces in Ansys CFD post gauthamnarayan ANSYS 6 June 8, 2015 08:33
Problem regarding producing streamlines from surfaces in Ansys CFD post gauthamnarayan Visualization & Post-Processing 0 April 23, 2015 17:07
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 13, 1999 00:27
