Turbocharger waste-gate simulation goes wrong |
May 21, 2017, 15:30 |
#21 | |
fazlin mohamad
Rep Power: 9 |
hye ghorrocks! this is my latest update for my chart. torque rpm.png seem like both of the curve is accending but i need to run more point to see what happen at a little higher rpm. all of this happen because of your help.i really want to thanks you alot. |
May 21, 2017, 19:48 |
#22 |
Rep Power: 144 |
It is unusual for a turbine to be operating in a regime where its torque increases with speed. This suggests it is operating a long way from its design condition, which probably means big separations and other nasty things.
This may be intentional - if so then please continue. But be aware that this system is not running at optimal conditions. |
May 22, 2017, 02:26 |
#23 | |
fazlin mohamad
Rep Power: 9 |
I think I may get this kind of graph because I am using load by using direct formula which is 2*pai*torq*speed/60 Maybe I should using isentropic load ? |
May 22, 2017, 03:21 |
#24 |
fazlin mohamad
Rep Power: 9 |
Ghorrocks I have just realize that my inlet pressure has drop too much with my added wastegate and my outlet pressure has become a negative value..I am so sad with my problem..thanks you for helping me so much..
May 22, 2017, 07:43 |
#25 |
fazlin mohamad
Rep Power: 9 |
Now i am trying to run the simulation with the outlet boundary instead of opening boundary. I try to set up my waste gate mass flow rate outlet to 1% of the inlet mass flow rate at 30000 rpm .maybe I can see something from there. The wastegate area also has been decrease to see whether it can influence the result.
May 22, 2017, 07:59 |
#26 | |
Rep Power: 144 |
May 22, 2017, 08:18 |
#27 |
fazlin mohamad
Rep Power: 9 |
I am so sorry for my reply ghorrocks.Maybe I should try my simulation with a smaller wastegate area. I guess my current area is too big for the turbine design condition.
Thanks ghorrocks for your reply. I really appreciate every knowledge you share . |
udf error | srihari | FLUENT | 1 | October 31, 2016 15:18 |
Simulation and Optimisation of centrifugal fan 3D to 2D | eRzBeNgEl | STAR-CCM+ | 0 | January 31, 2013 14:21 |
3D simulation with blended wingbody. Lift a 1/3 of what it shuld be. Any wrong? | SkunkWorks | OpenFOAM | 22 | September 12, 2011 18:29 |
Simple icoFoam simulation gone wrong | rieuk | OpenFOAM Running, Solving & CFD | 3 | March 5, 2010 03:24 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 15:29 |
