May 16, 2017, 12:04 |
Droplet Size and Velocity Measurement
Rep Power: 14 |
Hi All
Does someone have experience in doing Droplet size and velocity measurement in CFX for multiphase ? I also want to know if you can get the droplet size and velocity by doing VOF model ? Kindly let me know. Thanks in advance. |
May 16, 2017, 19:34 |
Rep Power: 144 |
If you are doing VOF (which strictly speaking CFX does not do, it has a different free surface model) then to get parameters like drop size and velocity- you will need to write a routine to extract that from the data. This is not straight forward.
May 17, 2017, 04:58 |
Rep Power: 14 |
Ok So what is the other models in cfx which can predict the droplet and velocity distribution ? Like some Eulerian or Lagrangian Particle tracking ?
May 17, 2017, 06:28 |
Rep Power: 144 |
Yes, both Eularian and Lagrangian particle tracking can predict droplet velocities and sizes for some types of flows.
May 17, 2017, 07:53 |
Rep Power: 14 |
But there is no tutorial to start with understanding how to set up the case.
May 17, 2017, 08:07 |
Rep Power: 144 |
There are tutorials on the basics of Eularian and Lagrangian particle flows in the CFX tutorials on the ANSYS Customer webpage.
But there is nothing specifically on spray break up models or other similar advanced models. ANSYS support will have some examples of these, you would need to contact them. But as these are advanced models they do not have beginner tutorials - as they are not beginner physics models. You are expected to be able to work out how to use these models from the description in the documentation and the theoretical model it uses. You are expected to already be familiar with the basics of Eularian and/or Lagrangian models. |
Droplet velocity in sprayFOAM | Tariq Ahmed | OpenFOAM Post-Processing | 0 | April 30, 2015 09:33 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 16:45 |
Importance of droplet size | Itchie | CFX | 2 | December 13, 2007 03:01 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 06:59 |
