Can CFX4 solve the problem with more than one outlets or inlets patches? How can I gain it? By editing the command file?
You can do it through defining outlets or inlets in command file(creat patch),or defining them directly in build. good luck!
you can edit grid file also ..if you are working in direction of changing into grid file ..please let me know ..i will help you in that regard ...or lese i am sending you a grid files starting excerpt from there you see how the grid file is modified ..
arjun |
Inlets - Outles activation time | Chucho | CFX | 5 | December 20, 2005 11:24 |
About Inlets & Outlets | Floydian | Phoenics | 3 | January 22, 2005 03:48 |
Multiple flow outlets | rahul | FLUENT | 2 | October 28, 2002 02:03 |
Multiple Inlets | Charlie V | FLUENT | 0 | May 28, 2001 02:29 |
create Volume with inlets | Roman Bohnes | FLUENT | 10 | December 6, 1999 04:43 |
