Import plot3d grid file
Old   November 21, 2001, 14:30
Default Import plot3d grid file
CFX new user
I have a number of grid belonging to different problems and I would like to test the those problems in CFX5.
I have imported the grid, but how does I place boundary conditions on this grid.
Do I have to make surfaces where the inlet and outlet boundaries are ?
Or how to proceed. The manuals does not help much.
Regards
New user.
Old   November 24, 2001, 17:10
Default Re: Import plot3d grid file
Patrick
Boundary conditions and source specifications can be placed on predefined 2D regions and 3D regions respectively.
If you are using volume mesh import mode to import a mesh from another source, you need to make sure that the appropriate regions have been defined in your source file before importing into CFX-5.
A word of warning here also - support for the PLOT3D format has been dropped for CFX-5.5 (release imminent). My recommendation would be to either convert your files to a more universally supported format if you can, or create Definition Files containing your PLOT3D mesh in CFX-5.4.1. These files can then be imported into CFX-5.5 in the same way as other mesh source files.
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
import PLOT3D GRID to ICEM-CFD autofly CFX 0 January 2, 2008 09:30
import plot3d multiblock grid to icem-cfd autoflly Main CFD Forum 2 May 11, 2006 16:47
