what is the meaning of the color of solid in Build |
November 20, 2001, 12:45 |
Hello everyone! I draw some geometry by CFX-Build. The surface,solid in Build shows different color: blue, green, red, peach, or yellow. When I want to create a solid from a surface by the extrude command, it send the message"only the green color surface can be done this process". What does the color of the geometry in Build mean? Can I change a peach solid into green solid?
November 20, 2001, 14:18 |
Re: what is the meaning of the color of solid in B
As far as I know there two kind of surfaces in CFX-BUILD. Bi-parametric (default color is green) and Trimmed (default color is green)surfaces. If you're intending to work with CFX-4, you must use Bi-parametric surfaces (the green ones) with 4 sides to avoid future meshing problems. In other hand, CFX-5 BUILD works with both kind of surfaces, green and magenta. Take a look at BUILD's manual if you're still in trouble. Regards, cfd guy |
November 20, 2001, 14:28 |
There's an error in my phrase. Trimmed surfaces default's color is magenta, not green
cfd guy |
How model radiation of both solid wall and fluid£¿ | Harry Qiu | FLUENT | 2 | February 4, 2013 00:04 |
Interfaces 2D - How to build between fluid and solid (fin)? | rogbrito | CFX | 0 | July 13, 2009 22:13 |
Multiple Solid Domains - Interfaces | Scott | CFX | 8 | July 31, 2008 16:20 |
how to build solid sub-domain | RON | CFX | 3 | June 2, 2003 14:28 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
