help me about the license key
Old   November 20, 2001, 06:40
Default help me about the license key
bin xia
Dear all
Would you please tell me how to put the license keys into the computer?
Thank you very much
Old   November 20, 2001, 06:44
Default Re: help me about the license key
Drona
I think you need to contact CFX support(I assume you are using CFX) for this.
Cheers
Drona
Old   November 20, 2001, 06:50
bin xia
Thank you very much. But they have sent the keys to me, and I don't know how to put it into the data file.(CFX 4.1)
Can you tell me what do you do when you renew your license keys?
Thanks a million
Bin
Old   November 20, 2001, 09:21
Drona
Well, it will be pretty difficult to explain how to install license by this method. Or at least it will be difficult for me. What I can tell you is look at the "Primer Manual" of your code(I still don't know what code you use). It should explain how to install the license. They send the hard copy of the Primer Manual with the code. You can also find it online. Should be in your CFX folder.
Hope it helps
Drona
Old   November 27, 2001, 06:50
arjun s y
dear i can understand your problem ...
well first thing you should do is copy the license file into licensing folder ... i hope you have located that folder .. now open that license file on the wordpad or any text editor where you can edit it .. now edit the folowing lines according to your system or copy daemon line as here written if you have installed on default settings ... this is for cfx4.3 and cfx4.4
# to serve the license SERVER cfd_new 0040055fd968 7157 DAEMON CFDS c:/cfx/licensing/CFXd c:/cfx/licensing/license.opt
then go to license manager ... then go to tools and say install .. the say start ...
it shpould start now further querries ... you can always write in thanks
arjun
Old   November 27, 2001, 18:47
Robin Steed
You should really contact support for this.
Old   November 28, 2001, 05:35
bin xia
Thank you a million.
I have solved this problem as your hints.
Kind regards
Bin Xia
Old   November 30, 2001, 00:32
arjun s y
oh good ..at least something is used .. you can bother me whenever you feel troubled .. for me it would be learning
arjun
license error CFDUSERIN CFX 6 February 22, 2020 01:58
License Error lffabiani CFX 2 June 30, 2011 21:51
ANSYS License Error vincentryan.s ANSYS 0 June 7, 2011 16:31
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
new license key antonio CFX 2 December 2, 2010 05:57
