Transient flow
Old   November 3, 2001, 05:50
Default Transient flow
omondi
Hi CFX Users,
I use CFX4.4 to model flow in a stirred tank. I have chosen fixed time step selected such that there is one time step per cell. However, when i run the solver, it keeps loosing information at every time step. Convergence occur only within one time step then shoots up again.
it is a problem similar to that of Keny(Posted as Unmatched boundary).
Any body with an idea?
omondi
Old   November 5, 2001, 14:59
Default Re: Transient flow
Ribeiro
Omondi
What you mean "one time step per cell"?
Ribeiro
Old   November 6, 2001, 03:12
omondi
Ribiero,
this is the time one node of the inner bolck (solid 1) takes to move from one node of the outer block (solid2) to the next node of the same solid2.
hope this answers your question, if not, please just shout again.
omondi
Old   November 6, 2001, 07:15
Herve
How many ietrations per time step are you using? If you use multiple iterations per time step, then you should see a series of "spikes" coming down showing that convergence is achieved within each timestep. This is a typical convergence plot for transient cases.
Old   November 6, 2001, 09:15
omondi
Hi Herve,
Thanks for taking your time to respond to this.
I use 20-100 iterations per time step. Yes, convergence takes place per time step, it then swings back to the original values, then converges a little and back again. And the oscillation continues.
regards
omondi
Old   November 6, 2001, 12:12
Herve
Okay so what you need to worry about is the convergence within each time step. This is the important feature. So check the convergence within each time step to ensure that after n iterations your residuals have decreased by x order of magnitude and that the solution at the selected nodes does not change. If this is not satisfactory carry out more iterations. I think the oscillatory feature you observe is fairly normal for a transient run.
Old   November 7, 2001, 05:39
omondi
herve,
it oscilates between 1.0E+03 and 1.0E+01 residual values. Yesterday I used 2000 iterations but there was no improvement.
In summary again my problems are: 1.No significant convergence 2.The solver tells me, in the output file, that I need pressure boundary [details of thes are in my 1st posting].
why?? Back to you Herve!
ochieng
Old   November 7, 2001, 08:12
matej forman
Hi, could you, please be more specific and write down what physical models do you use.
you should not need any boundary. at least I am doing combustion calculations in geometry with just walls. and it is working for 1d case. I didn't work out how to make it converging in 2d case yet.
Hi, Matej
Old   November 8, 2001, 02:47
omondi
Hi matej, How would you use a stirrer in a 1-D case?
If you read my first posting, you will notice that I specified some of the details I am now being asked towards the end of the string. However, I will always give the information again. -It is a stirred tank(conventionaly undestood as a cylindrical vessel, unless specified otherwise) -the vessel geometry conforms to the classical configurations (T=3D, T=H, Baffle, B=0.1T, 4 baffles) -agitator is Rushton turbine 6-bladed.
Incase this is still not clear feel free and ask for specific details of the geometry.
Problem with transient solution of flow past a row of cylinders jostanek Main CFD Forum 0 January 6, 2010 13:16
TRANSIENT ANALYSIS OF JET FLOW shriramjegan FLUENT 0 July 28, 2007 13:04
transient compressible flow simulation-urgent JSM FLUENT 0 April 26, 2007 02:51
transient compressible flow problem (urgent plz) jehanzeb FLUENT 5 August 3, 2004 09:04
PhD in turbulence Hans Main CFD Forum 14 October 8, 2001 04:03
