LES constant velocity boundary conditions
Old   April 24, 2017, 07:15
Default LES boundary conditions interface model
balrog_f is on a distinguished road
I am trying to investigate the effect of dimples to the flow. Therefore I want to do a LES where a specified airflow flows through an infinte channel of a dimpled and a non-dimpled wall (Re ~ 12000). Therefore I am using periodic boundary conditions in streamwise direction. What would be the approach for this, using the pressure change or the mass flow rate option as interface model?
My guess would be the mass flow rate cause I have everything I need for this (velocity, geometry). But I am not sure what I should use as pressure update multiplier? Or should I use pressure change?
balrog_f is offline   Reply With Quote
Old   April 24, 2017, 19:17
If you specify the pressure change then you get whatever flow rate that results in. If you specify the mass flow rate you get whatever pressure drop that results in.
So you use the option which matches the information you know about the flow. So if you want to run at a specified Re number that means you should use the mass flow rate option.
I am not sure about the pressure update multiplier, I would have to to look that up before commenting on that.
Old   April 25, 2017, 06:44
Okay I will try the mass flow rate option. I will calculate the mass flow rate via an expression, which then I will use at the additional interface model tab for the mass flow rate. I have my desired velocity (Ubulk) and my defined interface areas (channel "inlet" and channel "outlet"). My expression would look like this :
massflow = density*Ubulk*area()@inlet
Is this the right approach?
Old   April 25, 2017, 20:38
Sounds pretty good to me.
Old   April 28, 2017, 05:33
Thank you very much for your help Glenn. I will do it like this!
les, periodic boundary
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Radiation interface hinca CFX 15 January 26, 2014 18:11
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
OpenFOAM Variable Velocity Boundary Conditions NickolasPl OpenFOAM Programming & Development 2 May 19, 2011 06:37
