Convergence when clearance selected
Old   October 16, 2001, 21:18
Default Convergence when clearance selected
dandy
Hi,everyboy!
I meet convergence difficulty when clearance selected. I am using CFX-tascflow 2.10. The running problem is an axial compressor which composing twin stage. The problem is easy when clearance didin't select. Then, how can I do when clearance is selected to get a good convergence.Anybody has such experience? Thanks for your help.
dandy
Old   October 18, 2001, 18:13
Default Re: Convergence when clearance selected
Robin Steed
Hi Dandy,
There is no such selection "clearance" for TASCflow. Do you mean to say that you have created a grid which includes tip clearance? If so, what did you create it in and how did you bring it into TASCflow.
Regards, Robin
Old   October 20, 2001, 05:31
dandy
Thanks Mr. Steed sorry,I forgot it! It is as you said. I create the grid whit tip clearance in use of CFX Turbogrid 1.05. I really met a huge difficulty in running the problem when the grid including a tip clearance. By the way, the grid including tip clearance is as good as the grid without tip clearance in skew! Hoping for your help! thanks
Old   November 14, 2001, 12:06
Martin Bowers
If you are using a GGI clearance template (I suspect you are since you said min skew didn't change when adding clearance) you need to pay particular care to how the clearance grid lines up with the passage grid since the default grid distributions create vastly different spacings on both sides which in turn often cause problems for the GGI.
Check to make sure the clearance GGI has been created in Grid Interfaces. Make sure the initial guess is valid in the clearance region too.
Finally is the case stalled (numerically or physically) with the clearance included? The clearance reduces the stability of the flow and a case that runs with no clearance might not run with clearance for very good reasons.
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 15:20
Convergence problems Chetan FLUENT 3 April 15, 2004 20:13
