Transient calculation
Old   October 16, 2001, 04:19
Default Transient calculation
Zheng Yu
I use CFX4.3 to calculation transient gas-particle flow in fluidized bed. And the time step is set as 5.0e-4 s or smaller. But predicted time series don't show the fluctuation as expected.
Old   October 16, 2001, 08:57
Default Re: Transient calculation
Ribeiro
How do you visualize the results? With which software?
Old   October 16, 2001, 09:16
Zheng Yu
The post processor 'Analyze' can read the dump file. Or you can write the data in files by Userfortran.
Old   October 16, 2001, 09:44
Ribeiro
Both ooptions are possible. But I suppose that the information wasn't saved in time interval that could show the trasient behaviour correctly. You should calculate the time scale of the smallest phenomenum that you want to see in the flow. This time scale will be the time interval to save in dump file. Of course, the time step of the simulation has to be smaller than this time scale.
I hope this helps.
Old   October 29, 2001, 07:31
keny
non-normal shut down problem for transient calculation waynezw0618 CFX 1 May 31, 2009 06:46
age of air - transient calculation roadracer Siemens 1 July 14, 2008 05:34
Warning 097- AB Siemens 6 November 15, 2004 05:41
transient calculation Philipp FLUENT 1 December 12, 2002 12:45
tiffs from transient calculation Frank FLUENT 1 May 8, 2000 17:40
