Including gravity in calculations!!!
Old   October 12, 2001, 20:46
Default Re: To make it clear:
  #21
Robin Steed
Gilberto,
The hydrostatic pressure will have no effect on your simulation unless your fluid is compressible, or you have a thermal gradient. If you really want to see the resulting pressure, run the problem normally and using CFX-Post, calculate a new variable "Hydrostatic Pressure" as:
Hydrostatic Pressure = Pressure + Density * 9.81 [m s^-2] * Z
This will be the pressure you are expecting.
Regards, Robin
Old   October 15, 2001, 06:12
  #22
gilberto
Thanks, Robin for your clear explanation, and sorry about being bothering you a lot with the same issues.Only one final question, how can I add a variable, so I can get plots of it, and everything??
Old   October 15, 2001, 11:04
Default Well,
  #23
gilberto
Now I have thought about it, it makes sense, I was being a bit obtuse in the whole thing.
By the way, Robin, my boss wanted to ask you if you come from Waterloo, as he thinks they were the ones to start developing this program,there in Canada.
Thanks very much for your time, and for sharing your knowledge ,mate, I really admire your deep wisdom about the whole CFX.
Regards,
gilberto
Old   October 15, 2001, 11:06
Default Re: To make it clear: Creating variable
  #24
Robin Steed
Gilberto,
In CFX-Post, first create an expression for hydrostatic pressure (using expression editor in post), then create a new variable using that expression (using variables editor).
Alternatively, you could create an expression for hydrostatic pressure in CFX-Build. The result of the expression would be available as a scalar output from the solver.
Regards, Robin
Old   October 15, 2001, 12:27
  #25
gilberto
Sorry, man, but with respect to that, what do u mean by CFX-Post?I imagine it is CFX-Visualise.In there, I can't find any variables editor, or expression editor.Where can I find it?The thing is I already have mthe problem solved,is there anyway of plotting my newly defined variable(provided I can define it first), in CFX-Visualise?
Old   October 15, 2001, 15:33
  #26
Robin Steed
Gilberto,
CFX-Post is the next-generation post-processor for CFX-5. There is a pre-release version available from the community pages on our web site. The full version will be released with CFX-5.
Sorry, I assumed you had downloaded it already. You can either download the pre-release version, or go by my second suggestion, which is to create the expression in CFX-Build.
Regards, Robin
Old   October 15, 2001, 21:55
Default Re: Well,
  #27
Robin Steed
Hi Gilberto,
"By the way, Robin, my boss wanted to ask you if you come from Waterloo, as he thinks they were the ones to start developing this program,there in Canada"
I work out of the Waterloo office. At one time, this was the home of Advanced Scientific Computing (ASC). We continue develop CFX-TASCflow here, the CFX-5 solver, post-processor, and TurboGrid are also done out of this office. ASC itself was originally founded by Dr. Raithby of Waterloo and four of his grad students. They are all still here (except for Raithby, who has retired) and actively involved with CFX. I have only been with CFX for a year now, and I must admit I am very impressed (does it show? .
Just wait until you get your hands on CFX-5.5!
Best regards, Robin
Including Gravity Effect in turbFOAM Eslam Reda OpenFOAM Running, Solving & CFD 0 October 19, 2009 15:23
Including Gravity Component Robert FLUENT 1 November 30, 2008 17:05
how to consider gravity in CFX shrimp CFX 4 September 8, 2008 21:41
including gravity in 1D model Amir Filipovic Main CFD Forum 0 November 18, 2003 16:23
On gravity modelling... Drona CFX 7 November 22, 2001 11:28
