September 20, 2001, 00:34 |
Pressure units.
I'm using the CFX 4.5.1 visualise component to get an area weighted pressure over a surface on my model. The program is giving me pressures in units of kg m^-1 s^-2. i.e. kilograms per metre per second squared.
I'm a little confused as to what the units mean and how to convert them to pascals which is a much more sensible unit. Any help appreciated. |
September 20, 2001, 03:55 |
Re: Pressure units.
Pa=N*m^-2=kg*m*s^-2 * m^-2=kg*m^-1*s^-2, looks like the same, doesn't it?
September 20, 2001, 06:57 |
Re: Pressure units.
Sure does, thanks.
September 26, 2001, 15:44 |
Re: Pressure units.
hi also you can see it in any units go to utilities > set units
set the units there and then get it in the units you want. joseph |
October 1, 2001, 13:29 |
Re: Pressure units.
In Visualise, go to Utilities in the menu, and inthere you can see SET UNITS, you go there, and it gives you lots of different units, it changes directly.
Anyway, kg mm^-1 s^-2 is he same as kPa, hence Pa is the S.I. unit, so it is kg m^-1 s^-2. |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 14:45 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 18:19 |
pressure BC-natural convection | engahmed | Main CFD Forum | 0 | June 16, 2010 12:38 |
pressure in Natural convection??? | engahmed | FLUENT | 0 | June 14, 2010 13:51 |
Pressure Condition | sidd | Siemens | 0 | April 2, 2007 10:31 |
