Coal with EBU
Old   September 13, 2001, 08:54
Default Coal with EBU
Magnus
Hi!
I have encountered a problem when running the coal with EBU model in CFX4.3. Every time I run it the solver aborts the calculation after some number (>2) of particle itegrations without any error message. If anyone might have an idea about what my problem can be please respond.
Cheerio!
Old   September 13, 2001, 18:19
Default Re: Coal with EBU
Jan Rusaas
Hi' When does it stop, during the flow or particle calculation. Have you checked the output file, sometimes it is written there why it is stopped.
Jan
Old   September 14, 2001, 02:34
Magnus
Thank you Jan for your quick respond. It seems like I might have already found the cause to my problem. You see, I am simulating a gasification reactor for black liquor in a 2D axisymmetric model and I have just found out that I have, by misstake, set a angular velocity component for the coal particles. This might have been the cause to why the flow calculation stops (no message in *.fo) in between two particle calculations? The thing that confuses me is that the calculations did not stop at the first particle claculation!
Maybe you (or someone else) can help me with another problem? I have trouble when using USRPBC and COAL EBU model. It seems like the code overwrites my particle BCs (set in USRPBC) and stops the calculation after the first flow calculation? I have no trouble with a isothermal (no combustion) run with the same *.f file. Is there something that must be added when I use USRPBC with the COAL EBU model?
Have a good day,
Magnus
Coal Combustion simulation Yogesh FLUENT 2 March 20, 2024 14:19
Coal combustion and ash reaction kinetics sega Fluent UDF and Scheme Programming 0 January 21, 2010 09:05
Clean Coal Projects Clean Coal Projects Main CFD Forum 0 March 2, 2009 04:57
Coal gasification-problem with convergence Claudia FLUENT 7 November 8, 2005 03:08
moisture in coal combustion Sheng FLUENT 3 June 15, 2003 20:43
