August 20, 2001, 05:10 |
first node in turbulence model
I'm a beginner with CFD (CFX4.3): in dealing with the k-epsilon turbulence model I've to set the first node at y+>11.Since y+ is a function of the unknown friction velocity how can I estimate the first grid position? Are there any empirical relationships which allow a crude estimate of the friction velocity? Thank you in advance for anybody helping me.
August 20, 2001, 12:17 |
Re: first node in turbulence model
Yes, you can estimate the wall-distance you need to get a certain y+. There is even a nice little free online calculator which will do it for you - you can find a link to it in the Resources/Calcs/Misc section of CFD Online.
August 21, 2001, 09:20 |
In the manual you will see that you can set a USRSCAL (user scalar) to return the y+ values and plot it.
Regarding u*, for open channel for example you can use the crude assumption that a mean u* = sqrt(g*R*So) where g is the gravitational acceleration, R the hydraulic radius and So the energy gradient. |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
Adding a Turbulence Model | doug | OpenFOAM Running, Solving & CFD | 11 | May 21, 2018 14:54 |
SimpleFoam case with SpalartAllmaras turbulence model implemented | nedved | OpenFOAM Running, Solving & CFD | 2 | November 30, 2014 23:43 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 11:26 |
SSG Reynolds Turbulence Model | Georges | CFX | 1 | February 28, 2007 17:15 |
