July 30, 2001, 17:53 |
gas solid flow in a pipe
hi,
Previously I am using CFX 5.4, but ever since I start modeling gas solid flow, I switched to CFX 4.4 3 weeks ago I was overwhelmed with CFX build, which is much more complex. And I could not use solid B rep either. My aim is to simulate gas solid flow through 90 degree horizontal to vertical elbow. I was having trouble constructing a semi/circular surface which I want to extrude solid from. The following error appear: "The surface type used for this Action, Object, Method function is invalid. It must be of a type that when created, has the default color of Green." I was also planning to create a base curve so then I can just use create-solid glide to extend my surface into the whole solid. Is it wise to do this way, can you guys suggest a better way to construct this kind of geometry. I also did not the constraints and the unmatched boundary options. Is it something that you must do after constructing your geometry? In the constraints I read that if you have 2 unequal faces at the joints that you have to use the constraints. Can you guys tell me how to obtain a user manual and examples of gas solid flow? A user manual would be greatly helpful if I can have one. Currently I am working as an undergraduate student assistant in university. Your help will be greatly appreciatd. Thank you Pandu |
Pipe flow with obstacle - HELP | Min | FLUENT | 6 | January 31, 2017 15:28 |
Simulation time for unsteady gas solid flow | pandaba | FLUENT | 1 | October 14, 2010 01:04 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 13:14 |
Dispersed Solid particles in carrier gas (DPM) | Frederik | FLUENT | 1 | June 3, 2008 06:13 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
