July 2, 2001, 10:17 |
CFX4 2d geometry
Hi, I am a new user of CFX4.I am having problems to create simple 2-D geometries like parallel plates,axisymmetric pipe,circular cylinder etc.I am a bit confused about CFX-Build and CFX-Meshbuild.I have read the manuals carefully,but cannot figure out.Please help me on this regard. Thanks Sanjib.
July 2, 2001, 16:00 |
Re: CFX4 2d geometry
Dear Sanjib,
Create a surface in i.e. the x-y plane, create a solid by extruding this surface in the z direction, extrude by say 1. For axisymmetric the low-j should be a symmetry plane. Create the mesh and REMEMBER only one cell in the z-direction for 2d geometries. If you are using build and want to create an axisymmetric geometry, remember in the analyse to activate the slab=wedge. From mesh-build I think for creating axisymmetric geometry you should convert the geometry in mesh import where there is an option for axi-symmetry. Hope it helps, Regards Jan |
July 3, 2001, 01:47 |
Dear Jan, Thanks a lot for the suggestions. Regards, Sanjib.
July 3, 2001, 02:18 |
Dear Jan, can you expalin the main difference between CFX-Build and CFX Meshbuild? Regards, Sanjib
July 4, 2001, 07:08 |
Hi, Can anyone please tell me how to run CFX-Meshbuild i.e,how to get into that environment and start building geometries?I am new to this software and facing a lot of difficulties.I can run the CFX-Build,but it seems to be good for 3D geometries. Regards, Sanjib
July 4, 2001, 16:50 |
What kind of system are you working on? Winnt? Unix?
You don't need Meshbuild. It is a little old fashioned. Build can do it all (well, almost everything). Cheers |
July 5, 2001, 01:56 |
Hi Fonteijn, The system is Unix.Can u please give me hints on how to build a parallel plate geometry and a vertical axisymmetric pipe.I've tried a lot,but as I'm completely new to this,I'm not able to do it. thanks for your reply Regards, sanjib
July 5, 2001, 03:58 |
Meshbuild?
From the environment menu go to >>Pre-process :>Other pre-processing :>CFX-meshbuild That's not hard to find. Building a 2D-geometry? - Give in all free points in the x-y-plane - Create faces in the x-y-plane - Extrude the plane to a block in the z-direction - Create the grid and just use 1 grid cel in y-direction. - write the grid. I am sure there is nice example in the manual for a start. Regs, Gert-Jan van der Gulik |
July 5, 2001, 07:51 |
Re: CFX4 2d geometry;Thanks
#9 |
Hi van der Gulik
Thanks a lot.I've followed your instructions and obtained the geometry.Now I've some idea how things actually work. Regards, Sanjib. |
July 6, 2001, 03:30 |
#10 |
Hi, I'm having a difficulty to write a 2d geometry(parallel plates)file.Can anyone sort that out please. Regards, Sanjib.
July 7, 2001, 06:53 |
#11 |
Now, what's the problem?
July 9, 2001, 07:27 |
#12 |
Hi, does anyone know how to remove patches from the command line or how to modify a patch? Thanks, Sanjib.
July 9, 2001, 07:40 |
#13 |
Hi, to modify a patch in command file:
>>MODEL TOPOLOGY >>MODIFY PATCH OLD PATCH NAME,NEW PATCH NAME,NEW PATCH TYPE keywords are avalible. If you want to change a location, you can do it through the renaming to new patch,or - specify it either in meshbuild (or Build)and generate+write the mesh again, or in command file, which is more flexible when setting the case.I strongly sudgest to go through introductory examples. it takes you 1 day but saves much more back. good luck! matej |
July 9, 2001, 09:12 |
#14 |
Don't you have a manual? Many of your questions are very well described in the manual. I know it is difficult to start with a new code, but it is usefull to get familiar with the manual.
Good Luck Jan |
July 9, 2001, 09:18 |
#15 |
Hi Jan & Matej, thanks both of you for the suggestions. regards, Sanjib
July 10, 2001, 05:36 |
#16 |
hi,Sanjib I am also a beginner of CFX 4.1. Now I am learning CFX-build, but in my manual there is little examples, would you please tell me how many examples in your manual and can you use the on-line maual?
Thanks a lot. Wish we learn CFX smoothly. bin xia |
July 10, 2001, 06:56 |
#17 |
Hi Bin, There are 5 examples in CFX-BUILD and 14 examples in CFX-MESHBUILD.If you have only CFX-BUILD like me,then you have to access the online manual only.Initially it will be a bit difficult,you need to get accustomed.I am trying to solve some simple 2d problems eg.flow through parallel plates,pipes.I think this approach will be okay. Regards, Sanjib.
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 09:17 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 05:31 |
CFX4: 3d geometry | Ansah | CFX | 2 | July 17, 2003 05:33 |
CFX4 geometry and command file | a.melandinos | CFX | 1 | February 14, 2002 13:37 |
