Turbulence model
Old   May 30, 2001, 12:36
Default Turbulence model
pop
I need help modelling a low Re flow. My fluid domain has two zones one with Re almost 3000 near the inlet and the other part is lower than 1000. So now which model to use and what are the mesh restrictions I have.
I am using CFX 5.4.1
Thanks
Pop
Old   May 30, 2001, 14:49
Default Re: Turbulence model
B Malone
If the Reynolds numbers are really this low start out with a laminar model. Use the default mesh and see if it converges. Change mesh parameters to double the number of nodes and run again. Perhaps do this again. Are the solutions the same?
Try decreasing mesh size near areas where the residuals are the largest. Try to get at least 20 to 30 nodes in between all surfaces.
Check the results against any experimental data you have. Without supporting experimental data I don't trust it.
It will not hurt to try a turbulent solution. But 5.4 does not have a low Reynolds number model. You may need to look at version 4.
Old   May 30, 2001, 16:03
Default Solid-liquid flow CFX-4 or CFX-5
Vitidphan
Now i have to study solid in liquid flow model. Please tell me, how do the diffence between using CFX-4 and CFX-5 for this type of model. Thank you
Old   May 30, 2001, 17:31
Jan Rusås
Dear Pop,
I really do think you should investigate some of the Low Reynolds number models (in CFX4 ! if you can) But be careful with your mesh at the walls, y plus should be 1 or 2..3 depending on model. It is described in the manual under wall models.
Regards Jan
Old   May 31, 2001, 10:44
pop
Dear Jan, Thanks for your reply, however I do not have CFX4!!! There is no way in CFX5.4.1? Thanks
Pop
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 14:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 11:26
Fan heater model: what turbulence source to use? andy20 CFX 7 March 3, 2008 17:42
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 17:15
