CFX 4 for two continuous fluid flow solution
Old   May 17, 2001, 16:11
Default CFX 4 for two continuous fluid flow solution
sinjae
Hi, Is anyone can make comment for the two continuous fluid flow in a 2-D channel ? For example, water flows into the half of the duct inlet and air flows into the the other half of the duct inlet. All phases are separately flowing into the duct and there is an interaction at the interface between water and air inside the duct. Anyone can make comments on initial conditions, BCs, flow model, etc.
Thanks,
Sinjae.
Old   May 19, 2001, 04:07
Default Re: CFX 4 for two continuous fluid flow solution
Li Xinfeng
In CFX4's examples, there is a simple example about your question.you can search it in examples.
Flow through porous medium using CFX: lack of convergence Chander CFX 3 July 23, 2014 07:32
Fanno flow (pipe flow) in CFX Saima CFX 1 December 17, 2012 06:36
in CFX, how to define a inlet condition of feedback control flow rate ? suihenry CFX 12 May 14, 2009 18:59
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
