Initial guess for k & Epsilon
Old   May 2, 2001, 21:43
Default Initial guess for k & Epsilon
Helal
Dear All,
Can anyone let me know the best way to set the initial guess values for k and epsilon? What are the related assumptions to set these values? Is their any thumb rule for these? I need this information to set the AMBIENT VARIABLES in my command file.
With regards,
Helal
Old   May 3, 2001, 18:39
Default Re: Initial guess for k & Epsilon
James Date
Have a look in this book, it should tell you what you need to know.
"An Introduction to Computational Fluid Dynamics", H.K. Versteeg and W. Malalasekera, Longman Scientific and Technical, 1995, 1st Edition, ISBN 0582218845",
Regards James
Old   May 8, 2001, 06:11
joseph
hi
The initial condition for the pressure field should be the average of the highest value of pressure specified on any of the Outlet boundaries and the lowest value of pressure specified on any of the Inlet boundaries. This reduces the likelihood of spurious inflow at Outlets, or outflow at Inlets, during the course of the solution.
If you suspect that the flow is predominantly in a particular direction through the domain (for example, in the direction of an Inlet specification), you can set the Initial Guess to these velocity components.
Regards,
joseph
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 13:53
