Printing problem
Old   April 29, 2001, 18:24
Default Printing problem
Pandu
Helo,
I want to print my drawing from CFX build as appears from the screen. How do I do that
Old   April 30, 2001, 05:54
Default Re: Printing problem
Hyun S. Lee
If you are using Unix machine, use "snapshot" command , elseif you are running NT machine, check out numerous screen capturing utilities, such as Flash32(www.logipole.com).
Hyun S. Lee
Old   May 1, 2001, 08:17
Astrd
Windows environment? Then, if you are using Exceed, select (right mouse button):
- tools - toolbar - show - the button that says 'Copy rectangle to clipboard'
Then draw a rectangle which will be copied into your clipboard. Then paste it in whatever you like.
Cheers, Astrid
Old   May 1, 2001, 23:22
Default Thank you for your help!!!
Hyun S. Lee
Old   May 2, 2001, 07:27
Default Re: Thank you for your help!!!
Astrid
You needed help too?
Old   May 10, 2001, 04:16
Ratio
first to try this function
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 08:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
