beginner's question
Old   April 28, 2001, 22:32
Default beginner's question
icmyn
What is the difference between cfx-build and cfx-meshbuild? Thanks.
Old   April 29, 2001, 04:41
Default Re: beginner's question
icmyn
Old   April 29, 2001, 08:50
Gert-Jan van der Gulik
I prefer CFX-Meshbuild as it works works very intuitively.
CFX-Meshbuild
Main disadvantages:
- constraints are hard to implement, especially in 2 dimensions.
- periodic boundaries are not direct applicable, but there is work around.
- a little old-fashioned, a lot of handwork is needed.
Main advantage:
- as I said, it works intuitively.
- the deform tool. You can select part of the geometry and deform it relative to the other part (translate, rotate, scale etc.).
CFX-Build (I am not an experienced user)
Main disadvantage: It has no deform tool which implies that if you want to move parts of the geometry, you have to delete them and rebuild them at the new location. I think this is annoying.
Main advantages:
- modern setup, more automated.
- you can use parameters to define your geometry which is meant to be a substitute for the deform tool but I don't like it.
Regs, Gert-Jan
Old   May 8, 2001, 06:03
joseph
hi
Mesh build is an older preprocessor which came with CFX4,now they have cfx build which is based on PATRAN so if you are familiar with nastran or patran then the later will be cake walk.
cfx build is extremely friendly to use as compared to mesh build.
Regards,
joseph
Old   May 10, 2001, 23:53
Kenneth McConachy
Hi Joseph
Is CFX build also a better tool than Meshbuild to build , say, an impeller in a stirred tank?
Thanks
Kenneth
Beginner's Question - cannot see grid in ParaView fishlurch OpenFOAM 3 January 7, 2010 10:49
[Technical] Beginners question! DanL OpenFOAM Meshing & Mesh Conversion 1 June 3, 2009 12:29
A beginners question Pst Main CFD Forum 2 February 19, 2006 04:33
Beginners Question Aleks FLUENT 1 April 14, 2003 12:09
a beginner's question! tao-chong Main CFD Forum 2 November 18, 2002 22:17
