lateral excitation for sloshing in ansys cfx vof model |
March 15, 2017, 02:25 |
naveen kumar s
Rep Power: 10 |
hello
i have simulated a rectangular tank with roll oscillation. using cfx vof model ..means in the domain motion i have given angular velocity.. now for same tank in x axis i have to give oscillation motion like, going front and back in x direction (lateral excitaion) (x(t)=X0 sin (wt)). but in domain motion there is only rotation .. where can i give this motion in x axis the tank containing partially liquid it has to move like that equation. can anyone tell where can i give motion in cfx. please and urgent thank u |
March 15, 2017, 06:43 |
Rep Power: 144 |
Are you doing this using rotating frames of reference or a moving mesh model?
I recommend you do this in moving mesh as you can easily put in arbitrary motions, and it also takes proper account of the accelerations. Rotating frames of reference models assumes constant rotational velocity, so acceleration terms are not accounted for. And if your question is urgent then contact ANSYS support. That is what you pay them for. Nobody in this forum is being paid, so we will answer your question in our own good time. |
March 15, 2017, 08:20 |
naveen kumar s
Rep Power: 10 |
Oh i got it. No urgency
Ill do it in moving mesh only,, thanks Glenn Any initial parameters or theory i should know to do in moving mesh. |
March 15, 2017, 17:55 |
Rep Power: 144 |
Have a look at the CFX tutorial examples. There are a few which use moving mesh. You can get them from the ANSYS customer website.
September 25, 2017, 17:41 |
Martha Elena
ghorrocks please! Can you put the link for moving mesh examples?
lateral excitation, sloshing tank 2d, vof model, vof modeling |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 05:28 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 23:04 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 02:10 |
ANSYS to acquire CFX | Fred | Siemens | 0 | February 18, 2003 22:03 |
