Conbustion modelling with CFX5.4.1
Old   April 9, 2001, 08:01
Default Conbustion modelling with CFX5.4.1
David Hargreaves
Hi
Has anyone tried implementing the eddy break-up model in CFX5.4? I'm thinking of doing it via the CEL but before I do this, I would appreciate hints from anyone who's tried this already. I don't want to reinvent the wheel...
Ta.
Dave
Old   April 10, 2001, 02:32
Default Re: Conbustion modelling with CFX5.4.1
Li Xinfeng
In fact, YOu can't use the radiation in cfx5.4.But I think you can use the EBU combustion because the cfx5.4 can calculate the multi-phase reaction. If you didn't need the radiation. you can do it in cfx5.4. otherwise you have to use the cfx4.3. LI Xinfeng
Old   April 12, 2001, 08:15
Gavin
David,
Yes we have. Contact your local office and they will send you the CEL that Phil Stopford has developed.
Li,
If you contact your local office, you might get a pleasant surprise regarding the availability of radiation in CFX-5.
Gavin
Old   April 12, 2001, 08:52
Li Xinfeng
Relly? I will ask Phil stopford for CEL, But what is CEL?
Old   April 18, 2001, 00:54
Dan Williams
CFX Expression Language (CEL). Boundary conditions, initial conditions, source terms, most properties and algebraic additional variables can all be written in terms of a CEL expresssion.
For example, one could setup a mass flow specified inlet as a function of time, or set a parabolic inlet velocity profile. More complicated things are possible, and there are some examples of how to use expressions in the user documentation.
Dan.
Modelling unsteady 2D aerofoil drag xlxc34 Main CFD Forum 0 June 24, 2011 05:42
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 06:16
Unsteady modelling technique? Carlos FLUENT 0 September 26, 2008 12:37
how to ensure that your modelling is correct rvndr Main CFD Forum 7 March 1, 2004 13:21
turbulence modelling in cfx5.4.1 krishna CFX 0 May 13, 2002 13:47
