March 13, 2017, 07:08 |
CFX user ID error. Plz Help.
Syed
Rep Power: 9 |
I am trying to simulate a turbine blade in Fluid Flow (CFX). After importing the iges file into geometry and doing the mesh and then finally when I run the simulation after the setup. I get the following error : -
'Your user ID xxxxxxxxxx.... appears to be longer than 15 characters. This may cause rsh and therefore the Ansys CFX parallel code to fail on many platforms' And then immediately, I get the following message :- 'The ANSYS CFX solver has terminated without writing a results file. Command on host desktop exited with return code 0.' Please help me with this as I don't know how to set or change username.. |
March 14, 2017, 08:05 |
Rep Power: 16 |
It is not a problem with CFX; it is a limitation with rsh.
You'll need to talk to your IT people about changing your username, or increasing the character limit for user ids on your system. |
cfx & fluent, return code |
User Fortran with CFX 14.5.7 on winnt_amd64 | HLo | CFX | 22 | December 13, 2015 08:26 |
CFX User Fortran: Particle User Sources | hustxinxin | CFX | 0 | March 8, 2012 08:37 |
CFX 10 User Routine NOT in Fortran | Andre | CFX | 14 | August 8, 2006 23:03 |
CFX User Conf Proceedings Available 94,96,97 | Robert | CFX | 0 | July 5, 2005 14:54 |
CFX User Subroutine Archive | David Creech | Main CFD Forum | 0 | March 17, 1999 12:41 |
