Component update can be performed only in base design point
Old   March 10, 2017, 06:48
Default Component update can be performed only in base design point
Domenico83 is on a distinguished road
Dear All,
I am in ANSYS workbench. Amongst several simulations, I do not really know what happened. I got now an error message saying that
System.InvalidOperationException: Component update can be performed only in base design point
at Ansys.ProjectSchematic.Update.UpdateCommandProcess .GetUpdater(IFullContext context)
at Ansys.ProjectSchematic.Update.UpdateCommandProcess .<ExecuteAsSuspendable>d__1.MoveNext()
at Ansys.Core.Commands.Concurrency.SuspendableCommand WorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExe cute(IExecutionEngineCallback executionEngine, CommandContext subContext)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execu te(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ansys.Core.Commands.CommandFailedException: Component update can be performed only in base design point
CommandName: UpdateComponent(Component="/Schematic/Component:Solution", AllDependencies=True)
at Ansys.Core.Commands.CommandAsyncResult.WaitForSusp endOrComplete(Int32 milliSecondsTimeout, Boolean exitContext)
at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMe taData operationData)
at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction)
Then, if I try to remove other design points apart from the current one, I got another error saying that
The active design point can not be deleted
System.InvalidOperationException: The active design point can not be deleted.
at Ansys.ParameterManager.Commands.DeleteDesignPointC ommand.Execute(IFullContext context)
at Ansys.Core.Commands.Concurrency.CommandWorkUnit.ex ecuteInContext(CommandContext subContext, IExecutionEngineCallback tracer)
--- Ansys.Core.Commands.CommandFailedException: The active design point can not be deleted.
CommandName: Parameters.DeleteDesignPoint(DesignPoint="/Parameters/DesignPoint:2")
at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
at Ansys.UI.Standard.DeleteSelectedDesignPointOperati on.Invoke(GuiOperationContext context)
Do you have any ideas about what is happening?
Regards,
Domenico83 is offline   Reply With Quote
[snappyHexMesh] "no base point for face xxx - produces a valid tet decomposition" eugene.katsevman OpenFOAM Meshing & Mesh Conversion 18 April 7, 2017 12:35
ERROR: Update failed for the Setup component in Fluid Flow (CFX). amsys Main CFD Forum 0 June 13, 2016 11:53
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
